Modifications
Have you done a few modifications to your car? Or gone all out and made a load of modifications? Why not start your own build thread in the NEW Ford Projects and Builds section ( http://www.fordownersclub.com/forums/forum/89-ford-projects-and-builds/?prune_day=100&sort_by=Z-A&sort_key=last_post&topicfilter=all ) and show off your motor and what you've done to your pride and joy :) maybe even get some inspiration on what to do next from looking at other peoples threads :).
OR
If you just want to discuss something to do with modifying why not post it in the NEW dedicated Modification Discussions section http://www.fordownersclub.com/forums/forum/90-ford-modification-discussions/
Enjoy
FOC :)
  • 1 month later...
  • Replies 201
  • Views 156.1k
  • Heres the build thread shows other things aswell as what's been guided; I cant think of anything except the factory turbo which I'm quite proud to have considering it's a 1.6TDCi pushing 35% mor
  • KlingKlangMan
    KlingKlangMan
    Is there a way to make the bonnet release on a Focus a SENSIBLE one with a pull under the dash, rather than the "AARRGGHHHHH!!!!" inducing Ignition Key one?
  • KlingKlangMan
    KlingKlangMan
    Yeah, I was looking for SVA approved ones, and the flat ones with handles look the best. meanwhile I have to get the *four letter word alluding to a lady's front bottom* to open on the key, and the ke
  • 8 months later...
Has anyone fitted a omex launch control to the mk1 1.6? If so do I use the same ecu wires as the fiesta zetec s? Thanks.in advance :-)
  • 4 months later...
My build thread on the focus page needs moving now :)
drop me the link to what you want moving and I will pop it over to the builds section for you.
  • 2 months later...
  • 3 weeks later...
What can I do to make my focus zetec fast ?
Faster
  • 2 months later...
I was looking into this on the cmax but had to get rid of the car in the end. It is possible but requires a fair amount of work. You can remove the bonnet lock assembly and replace it with one from a car like a fusion or mondeo, it would then need to be welded on in the right place.ypu then need to make a hole through the firewall and feed a release cable and it's sheath through there and attack it to the primary release on the bonnet catch, and then fit an internal release on the inside, you might need to weld this on the inside or bolt it onto place. You will need to adjust the length of the cable and test it.
It is doable but not the easiest to accomplish but would be well worth it.
Hmm.... Or I suppose there the option of just throwning the whole damned thing away and using locking bonnet pins. ;)
I also explored that option :-D
Anything come of it?
I was tossing and turning but favouring the new release mechanism. Bonnet pins would definitely have worked, but it's best to get the flat handle style with keys to unlock as a protruding pin could be an mot failure. My car was crashed into and exchanged a short while before I started the conversion.
Yeah, I was looking for SVA approved ones, and the flat ones with handles look the best. meanwhile I have to get the *four letter word alluding to a lady's front bottom* to open on the key, and the key won't even *four letter word alluding to 2 people doing something very intimate* TURN!! *Word alluding to Child born out of wedlock*!
*sigh*
Haha loving the substitutes lol.
Press down above the catch at the same time and you should stand the best chance
I've tried that, too. I fear the Angle Grinder option will be the only way forward, because as useful as the "How To" is in the Guides section it doesn't seem to apply to the Mk1, which has a box around the back of the lock mechanism. There's a Youtube vid of someone just drilling the son of a *word meaning Canine Female* out, but I'm not sure how far to drill!!
It could be cheaper to take it to ford, otherwise you will have to replace the bonnet. On a plus side, you would have a bonnet to practice drilling through for the pins lol
I KNEW I should have kept my old Mercedes 190E! That was almost indestructable!! :(
Sadly the focus weak point is the lock, ford will charge about 300 to fix....
Yeah, no wonder the f**king things are so "Combustable" :/
I would get ford to do it if your going for replacement, but if your going to do yourself the job, I would definitely look for the replacement though, depending how long you want to keep the car.
Given that the car was only 200 quid I think lobbing out 150% of purchase price just for the bonnet release is a teeny bit OTT. The guy opened the bonnet before I drove it away, so I KNOW the *Word meaning child born out of wedlock* WORKS! :( *sulk*
Do I REALLY need to resort to THIS??
I think if you spent that little on it, it's worth beating it! Even if you destroy and disintegrate it, you can then put the pin setup on it.
I'm open to offers of help.
