Ecu Location/removal 2.0 Tdci
This should be real simple. Where is my ECU? ECU repair company needs the serial number before they'll agree to repair it.
Thanks, Mark.
It should be behind the wheel arch liner on the front left side of the car.
Thanks so much. I'll check it tonight.
Yep thats where it defo is you will need a torx key to remove the cover.
I didn't know about the torx key but thankfully I have some. What a pain to get there. Jack car, remove wheel, remove arch liner, remove protective ECU plastic cover (4 torx bolts). It will be easier next time!
  • 4 months later...
hei mate did you get out the ecu?What car you own FOCUS 2.0 TDCi?Can you tell me what ECU type does it have?
