Fuse Issue
Hi all. Got a problem with my 07 focus st. My cigarette lighter has broke and I want to check the fuse, however the fuse diagram in the book does not match the fuse box in the car. It says its fuse 109 but the fuses don't go that high. Any ideas? Thank you
Look for a post from stoney he has the diagrams on his signature worth noting that inside the lighter barrell theres two blade like prongs using something non metal if you bend each in slightly so they protrude into the barrell a bit more works if they dont make good contact it doesnt work
Ill give that a try cheers
Link to the fuses is below this post :)
For quick info - It's number 39 (top row 20A)
Thank you stoney
