Flashing Airbag Light
I got a flashing airbag light ? It just randomly come up. I've checked the seat connections but there connected . It's flashing constently . I've been told it may be clock spring but the horn works fine.
That's fine. Everything is fine. I've checked everything that goes into the airbag. The only thing it could be is clock spring or the module. But the module could be fine as it's finding a fault as it should do. Or it clock spring but the horn works so. It's a complicated system. I'm going to connect it to the computer and see it that sorts it out. Might also disconnect car battery for about an hour.
Found out the module needed programming again. All sorted.
