2.0 Tdci Whistle?
Is it normal at around 2000 rpm for it to makes a whistle noise? Its done it for 3 yrs but just curious
Its hard to explain I can hear the turbo spooling up and as I floor it as its passing 2000rpm it gives a whistle like its realeasing presure
Check the pipes and hoses for any cracks or splits, this is a common query that may be worth investigating.
Will do it doesn't lose any power and theres no smoke or anything ill have a good look around just incase
my car does smoke, but doesnt lose power either, I believe I know what the problem is (as to how to fix it, is up for discussion) but whistle is either meant to be there (standard turbo whistle) or its a tube, pipe or hose somewhere that should be better.
Silly as it is, check that the air filter box is fully secured. If there is a crack (where, for example a small stone stops it closing entirely) that could also cause the whistle
I took airbox off other day to clean the filter lol but its done it since ive had it and kind of like it lol, one thing ive noticed lately is if im say in 5th with my foot to the floor Im sure I can feel a dip in power and then full power but very very slightly, do you know what could cause this? Thanks
sounds like the normal lag that you tend to get with these fly by wires, otherwise it sounds like the car is either not delivering air, fuel or spark exactly where it should be...
Its weird but bearly noticeable but once o norice something once im always checking it lol
lol, keep an eye on it then, but if it is becoming a problem you may need to clean a few things, inlet manifold, MAF sensors, and checking the likes of the fuel filter again.
