Leaking Coolant Connection
Im a new member and am looking for some help in getting a part name or number if possible to buy it online.
I have a mk2 focus 1.6 ti and the connector where the coolant hose meets the heater core hose has started to leak slighly.
Im looking to know i anybody knows what this part is called or has a part number for it as im coming up blank trying to search goolge
for one, here is a pic of the part in question
http://i.imgur.com/Hlcnr2q.jpg
Thanks in advance
Hi Stephen, If you can provide me with the numbers printed on the hose where I've indicated then I should be able to locate the correct group of parts and provide you with the information you require-
post-28494-0-24086900-1378651596_thumb.j
Hi Stoney
Thanks for the quick reply heres the number and a pic of that part
3m5h 18k580 bb ecs5d, >epdm<, pl
http://imgur.com/bGCjDYQ
Hi Steveo ,Past experience with the spring clips is the expand and don`t hold as good as when new ,can you just not put a new `jubilee clip` on that you tighten with a screwdriver ??
Left hand hose is part (Finis) number 1250814.
Right hand hose is either 1251247 or 1322153 depending on whether your engine is the 90ps or 110ps version.
Easiest way to check is via http://www.etis.ford.com/vehicleRegSelector.do;jsessionid=40A3040661506375859EF400F7887895.eccvas507
Enter your VIN or registration mark and you should be able to acertain the engine type.
post-28494-0-41315800-1378653155_thumb.j
When i enter the details it comes up as 120ps
Focus 04-08/Focus C-MAX 03-07, 1.6L Duratec-16V Ti-VCT (115/120PS)
would that be the same part as the 110 you have listed
I'll check again in the morning for you.
Afraid i'm away from my computer until then so can't access microcat.
Right, rechecked Microcat for you and have the definitive and correct numbers for you-
1250814 will be about 15 Euro and 1337142 is about 25 Euro.
post-28494-0-91832700-1378702916_thumb.j
