05 Tdci Zetec Fiesta Injector
Hi I am new to the forum so I will try and explain what I am looking for. I bought a 05 TDCI Fiesta 75000 miles on the clock. The second injector from the T-belt had a bit of blow by on it so I decided to take it out clean it and replace the bush and copper seal. But when I stripped the engine down to expose the injector I see that someone was in there before. I am not sure if they broke the stud holding in the injector (will find out later) but they had replaced with a WF8.8 Stud in its place. I believe that the threads are destroyed and I need to tap the head so I can put in a new stud( or more work if stud broken in there). I do not want to remove the other ones to see what type of stud they are. So can anyone tell me the original length of the bolt ( that way I can tell if the stud was broken). Also what the size of stud is and the pitch and if its fine or course thread. Also if anyone has done this before what size did you go to on the replacement stud and what the specs are for that stud. This information would help me out a lot. Thanks in advance
