Mk 7 Battery Refit And Reset
hi i want to fit a rear view camera and not sure what i need to do
do i need to take the battery off if so how do you disconnect and reconnect and reset what ever
can i connect camera and screen to rear brake cables
i am a bit worried about doing this without advice
many thanks to any one who can advise
pip
If you want to disconnect the battery undo the 10mm nut on the black terminal to loosen it's grip and pull off the clamp.
I'm no expect on this but I would have thought you'd want to tap in to reversing bulb so camera powers up when reverse engaged.
would i need to do anything when i reconnect the battery i e any codes
Shouldn't do, no.
Pip, no need to remove the battery if you want to fit a rear facing camera (or a front facing one for that matter). Scroll down the threads on this forum and you'll come across my 'fitting a reversing camera' topic. It's pretty easy and cheap to do.
