Paint Code
Were can I find the pain code on my mk1 focus
It will be on the metal plate under the bonnet. However, if you enter your reg or chassis number at Ford Etis then it should tell you what colour you have.
Iv seen the plate but how do you work out what the colour is ? It's just numbers and letters ?
Probably easier to try Ford Etis as I mentioned above. Try out the link I gave you and put in your reg or chassis number and it should tell you the colour as well as a load of other information about your car.
If you look at the small information plate at the back of the drivers side sill near the door catch the paint code is the second box up from the bottom left side of the plate.
