Right Side Headlight Not Working
For anyone having an issue with dipped beams (normal lights) on the mk3 focus, the solution is cheap and fairly simple.
Step 1 https://amzn.eu/d/j7ROw4G buy something like that.
Step 2 download Forscan for your laptop
Step 3 plug adaptor into cars obd2 port and connect it to laptop.
Step 4 run the BCM reset command.
Step 5 clear all fault codes in the car.
Upon completion the BCM will function as normal and start providing 12v to all lights instead of 6v.
I know this is brief but all information on each steps can be found by a simple Google.
  • 9 months later...
Hi my ford ecosport right head light set not working, mechanic saying it have Body control module issue which is BCM . My vehicle is 2019 titanium trim. Can anyone helped me how to fix this BCM since it does have any kind of relays or fuses. All my fuses in fuse box are working fine.
mechanic said there is a communication issue in BCM . He said on  connecting on board diagnostics tool of ford
can some one please help with this
You need an Auto-electrician, not a garage mechanic.
Yes he is an automobile electrician from ford service centre who connected obd and checked that Bcm is having communication issue. Are you having any solution for this
Whats the DTC ?
Take it to an auto electrician
