Delayed Accelaration
Hi, was wondering if anyone could help me with a couple of problems I am having with my Ford Focus 1.6 LX.
1, When I try to accelerate sometimes the rev counter will rise but the car does not accelerate but then jumps into life like I have put my foot all the way the way through the footwell.
2. When I try and change gears sometimes the gear stick does not engage (no noise), but other times it seems abit rough/okay
Greatly appreciate any feedback
Any lights on dash
Engine management light comes on and goes off intermitly
Do u know what faults
Not sure but my mate cleared them down. Will ask him the errors and post later on
You have the make,(Ford) model,(Focus) the capacity (1.6) and the trim level (LX) but not whether it is a petrol or diesel engine
1 clutch is slipping , it may be worse uphill or under a heavy load
2 clutch is dragging
Could be your clutch simply needs bled - or master or slave cylinder/ CSC is leaking, - if the CSC or plates are gone it could be a big job to fix it as the gearbox will need to be dropped
Mate doesn't remember the code. Any help would be greatly appreciated
Its a petrol. Does your reply mean that both problems are linked? Very much a novice :)
Does this happen worse in gear four an five simple way test ur clutch jump in car put in fourth gear come off clutch an give gas like u taking off from lights if car don't cut out ur clutch gone
Yes - could be linked to a clutch fault
As others have stated, it sounds like the clutch.
Check the clutch fluid level and if its low it could be a leak. It is shared with the break fluid cylinder however so unless your breaks are new its normal to see a drop in the tank.
Also check if you can see any wet/greasy looking areas near the master and slave cylinder, this too will indicate a leak.
What's your mileage? Any work been done recently?
Luke
It defo ain't fluid leak if clutch slave is burst u would loose pressure an have no pedal sounds like clutch slipping cause only happen during acceleration
Not necessarily if its a slow leak, the clutch would still disengage and slowly engage causing the gears to stick? Just thinking there could be more than one issue.
I agree though that the best guess is the clutch slipping.
Luke
