My New Focus......
So....I've had the job list from the repairers and can finally share what's happened to the car
Parts / Panels Requiring Renewal
CAR CARE KIT
BONNET MOULDING
LEFT HEADLAMP ASSY
FRONT BUMPER
L.F FOG LAMP
L.FOG LAMP COVER
L.F LWR BUMPER TRIM
L.F UPP BUMPER BRKT
MODULE COVER
MODULE BRACKET
FRT LOWER AIR GUIDE
L.DOOR MIRROR
L.DOOR MIRROR HSG
L.DOOR MIRROR GLASS
L.D.MIRROR INDICATOR
L.REPEATER LAMP BULB
L.F OUT H.LAMP BRKT
L.F WHEEL
L.F TYRE
L.F TRACK CONT ARM
L.F SHOCK ABSORBER
L.STEERING KNUCKLE
L.F WHEEL HUB.BRG
L.F HUB CAP
L.DRIVE SHAFT CPL
L.CONNECTING ROD
L.F ABS SENSOR
L.F WHEELHOUSE COVER
L.F WING
L.F WING INN UPP CVR
Parts / Panels Requiring Repair
REPAIR BONNET
REPAIR L/APRON REINF
REPAIR L/F DOOR LOWER SECT
Associated Work Required
PULLING FRONT PANELS
CHECK FRT LOCK CARRIER
CHECK L/F DOOR FRAME
CHECK ENGINE CARRIER
CHECK L/F BRAKE DISC
CHECK STEERING GEAR
CHECK ENG REGULATOR UNIT
CHECK AND QUALITY CONTROL
CHECK AND ROAD TEST
Parts / Panels Requiring Painting
L/F WING NEW PART PAINTING
L/DOOR MIRROR HSG NEW PART PAINT K1R
BONNET REPAIR PAINTING <50%
L/F DOOR LOWER SECT REPAIR PAINTING <50%
L/APRON REINF SURFACE PAINT
Additional Items
ESTIMATE FEE
CLEAN CAR
E.P.A. CHARGE
METHODS RESEARCH
Cost Summary
Labour - £897.05
Parts - £2,408.82
Paint - £419.93
Additional items - £43.00
Total - £3,768.80
VAT @20% - £753.76
Total inc VAT - £4,522.56
So as you can see a fair bit of work....i've also attached the pics for anyone interested.
Images.pdf
Ouch, quite a workload!
  • 3 weeks later...
Update...
I received a call from the garage last Friday saying the car wasn't going to be ready for Monday as they still hadn't had delivery of the Drive Shaft.
Called them this morning and they told me I should have it back tomorrow night!
Dashboard camera is on its way. I got lucky this time when she admitted it straight away.
Cheers
DashCams are brilliant. If only there was a system that could wire up to every door and watch every darned angle!
Wow what a nightmare , you have had , owning a car for two hours and then that happening.
Glad they did not write it off.
yes Dash cam is 100% a good idea.
If you don't want to buy a dash can. I use an app called isymDVR 2. I use it on my iPhone. I record everywhere I drive.
Off to the Garage this afternoon to pick her back up!
Just hope I don't fall out of love with the car
Hope she's better. Don't let some idiots driving put you off your car. Stick some tunes on and have a nice drive. You'll love her again :)
Got her back. Was weird driving the car again. But the car has developed a squeak from some belt on the drivers side of the engine. Back to the dealers tomorrow
Sent from my GT-I9505 using Ford OC mobile app
