Mk7.5 Wing Mirror Indicator O/s Drivers Side
Somebody clipped my wing mirror yesterday and broke the indicator bulb housing and cap cover, everything else was fine. After replacing the bulb housing (part was £22.80) it cosmetically looked back normal, however the bulb isn't flashing, tried changing it thinking bulb might of internally smashed, still no luck. Tried all the fuses in the engine bay and all showing fine with a continuity check :/ wondering if anybody had any other ideas of possible cause or what to check ? Help would be appreciated. Thanks again
Have you checked to see if there is power getting to the lamp holder
Going to check when I get a minute, see if I am and if not work backwards to find the fault :(
