Omex Rev Lim
Hi all can anyone shine some light on what an omex rev limiter and launch control system does and how? They are £90 and look alright but the only thing i can see it do is causing a misfire and flames spitting out the exhaust ??
Cheers
Correct! The rev limiter works by cutting the spark to the engine and limiting the revs, when the power is back on the un-burnt fuel ignites in the exhaust hence the flames.
The launch control is a pre-set rev limit you specify, so from standstill you floor the throttle and the engine will hold at a certain rev limit. You dump the clutch and away you go.
Cool, so is it something good to have?? Easy to work?? Or just for looks??
It's your car and your decision.
Goon on a racecar, bad on a road car. Cars with launch are for track day use really, not every day. Unless you want to look like a twerp.
Unless you go on cruises and such, in which case fair play to you and it might be a worthwhile addition.
Naa i think im good lol, dont really want that sort of attention
Cheers
