Indicators And Heater Issues
My Indicators and heater blower not working on my 2000 fiesta.
You need to start your own thread.I will create you a thread in the Fiesta Section called Indicators and heater issues.
Is it only one side, or both side indicators? and do the heaters blow out at all, or just on setting 4?
Both sides,hazards working. blower not working on any setting.
Have you tried disconnecting and reconnecting everything at the fuseboard?
Will try it,can I get a fuse relay layout on this site.
There are some for the focus but not that I have seen for the fiesta, its not the fuses you need though. Drop the fuseboard, and you should see relay harnesses plugged into the fuseboard. Start by disconnecting the battery.
Once the battery is off, then start disconnecting the harnesses so that all that is left on the fuseboards is fuses, and no wires.
Then, replug everything back in and make sure it is tightly in place and secure.
