Clutch
hi there i went to start myford fiesta 1.25 2004 the clutch peddle is going up and down finethe plastic bit is still on peddle does this mean i need new clutch
Wat exactly do u mean
there is no resistance when pressing clutch peddle
Check ur brake fluid level it's either clutch master cylinder or slave cylinder inside gearbox is most likely ur issue
cheersbought mastercylinder today do i need to bleed clutch after i change it
Yeah u will need bleed it was it leakin
were will it be leaking from just going out now aftre 12 hour shift happy days were is the bleeding niple thanks for replying so quick
So what made u buy clutch master u bleed it through slave cylinder on gearbox they not an easy job to replace
just replaced it now someone on here told me to replace master cylinder first going to try and bleed it nowlet u no how i get on cheers for help much apreciated
the spring was a nightmer but got ther in end
mick just bled system cluch working fine plastic bleed niple lift metal clip tunn with hand simples cheers
for those who are going to try this therself i used a lace to strech sppring took me about20 min but got there in end
Did it fix problem could u see damage on old one
