Wheel Centers
Anyone know the size of the wheel centers on a mk7.5 ZS? should be getting mine in the next couple of weeks and want to order some DMB's ready for when it arrives.
Also planning to buy an "S" badge for the front grille. Someone who has done this already... will it just stick on using the sticky foam back? if not.. what have other people done to keep it there securely?
Not sure about the centre caps but with the front s badge just remove the 3m tape on the back and scuff the plastic with sand paper a tiny bit where u want to put it, add some super glue on the badge and the scuffed area apple some pressure and job done :) wont come off then haha mine hasnt :)
Lol thanks but not what I wanted to hear. Probably give the car back after a year or so rather not sand N glue and then have to replace the grille. May have to try and make some sort of clip
Sent from my GT-N7100 using Ford OC mobile app
I think you can buy a clip of a um corsa um !Removed! mobile as they are otherwise known haha, but ive seen them work before or snap the clip off an air freshener and glue the badge to that im sure that would work
Cheers will have a look :)
If it's same as MK7 will be 55mm.
I have the 17 inch and it's 55mm on the mk7.5
I also just stuck my s badge on with the foam backing supplied and it's been on since September no problems
That's good to know Nathan cheers :)
I didn't go for the 17's. Not sure whether to just order some 55's as dmb think that's what they'll be. Gonna get some S logo ones though which means they will need be made and they are saying 10 days for delivery so will be quite a while if it's wrong lol
