Miss Fire
Can anyone help got a diagnostic done on my mondeo 1.8 duratec 2004 the code was p0301 how do i cure this? The symptoms are missfire from cylinder1
Without investigation the problem could be anything!
I would start with checking plugs, leads and ignition coil though - most likely suspects
I always try cheapest fix first! So I'd probably try plugs first, then plug leads, then coil pack. May also be an injector problem.
