Nearside Rear Light Problem
as anybody had this problem?
when you press the brake pedal, both rear lights work, when you put the lights on, all lights work as they should, now when you have the lights on, position 2, and the press the brake pedal, the rear nearside light goes out, eg no brakelight or driving light. any ideas.
Bad earth, you need to check the earth point on the pillar, and also check the wires to the light cluster to make sure all is correct!
cheers, will check it, where abouts on the pillar, is it hidden?
I think its inside the boot behind the plastics but cant say for definite.
Thanks, will try that.
