Mk4 Lower Grill Surround
Hi all, some muppet gave the front of my Mondeo a little tap in a car park the other day. Luckily the only damage seems to be the chrome surround of the lower grill. I'm not sure if one of the grill clips is also broken as well though, there seems to be a bit of give in it.
Anyway, does anyone know where I can get a replacement of this surround? I can't find anything online after a bit of a search. Pictures below...
Cheers
Ford is the best bet for a direct fitment. You should remove the number plate then pull the trim off, then refit the new one.
I replaced one on my 2008. Most of the clips broke when I took it out. Use 2 old credit cards to push behind the trim then wedge a screwdriver in between them, stops you scratching the paint on the bumper.
Was under £30 I think. Only problem was the upper one now looks old and tatty in comparison.
