Mondeo Mk4 2005 2.0 Tdci Gear' S Problem
Hello All.
There is a problem with selecting 1st and rear gear on my brothers mondeo.
Sometimes it takes two three tries to select but sometimes it works fine, other gears work fine as well?
He was reading thru this forum and found that it might be some kind of leaver,or probably the oil, but the topic was old.
Any thought on this issue.
Thanks All in advance.
Hi Andy,
First things first, is it a MK4 or 2005? it cant be both :) MK4 is 2007 onwards, I suspect you mean a MK3.
Either way, I would say check the gearbox oil and consider replacing it if its in dire health! if its only first gear and no others, does it behave better when its warmed up? if so, this would indicate the oil could do with a change, however, if its no any better it might be the gear linkage thats the issue.
That shouldn't be the case. The Mk IV started in 2007. Anyway, I assume that it is a normal, 'H-patter', gearbox with six forward gears?
What happens when it doesn't go in? The gear lever doesn't goes as far as normal, but is then blocked?
Is it the case that the clutch travel is normal, or does the clutch only work at the bottom of its travel. If the issue is that the clutch doesn't fully disengage when depressed (either it only works at the bottom of the range of travel, or the car tends to creep when the clutch is down, but the car is in first/reverse on level ground), then the problem is probably the clutch (or initial stages of a DMF problem) rather than the gearbox.
Assuming that the problem isn't the clutch, then the gearbox oil is the next thing to suspect; probably the car has done a few miles by now, so changing the gearbox oil isn't a bad idea, anyway.
<Edit: Usually, it is the case that 'bad gearbox oil' is worse at start up, in winter, so if it is worse then, you probably want to change the oil.>
Gear linkage is a possibility, but usually gears 'wander' around a bit, if a linkage has gone bad. It is always (imho) worth lubricating the gerabox mechanism with, eg, bicycle chain lubricant, as this sometimes helps the feel of the shift, but that isn't usually enough to make blocking gears work again.
Have you, or your brother, tried double de-clutched changes from second to first at low speed? Does that work?
It happens as you said, it seems that something is blocking it
the clutch is alright
<Edit: Usually, it is the case that 'bad gearbox oil' is worse at start up, in winter, so if it is worse then, you probably want to change to change the oil.>
it does not mater, it can happen at any moment
can you please explain how to do it
It is mk3
