Crankshaft Pulley - Dmf Replacement - Mondeo Mk3 2.0 Tdci
I own a 2005 Ford Mondeo 2.0 TDCi. I have owned her about a year and currently has around 122k miles on the clock. Since I purchased the car a whole bunch of things seem to keep happening.
There are however 2 issues right now:
1) Noisy engine, this is coming from the Aux belt / Crankshaft pulley.
2) DMF is failing, it is grating into the starter motor which I had replaced around 5 months ago. It also noticeably squeaks when I use light engine breaking.
I am looking to purchase all the required parts and get a mechanic to replace what is needed.
For problem 1 I have so far purchased:
Crankshaft Pulley: http://www.ebay.co.uk/itm/150856526547?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Belt: http://www.ebay.co.uk/itm/300616403475?ru=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D300616403475%26_rdc%3D1
I intend to purchase a tensioner also since I hear it could be causing the issues:
http://www.ebay.co.uk/itm/Ford-Mondeo-Alternator-Belt-Auxiliary-tensioner-Mk3-2-2-2-0-TDCI-Drive-Fan-/140859877567?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3AMondeo%7CPlat_Gen%3AMK+III&hash=item20cbe728bf
For problem 2 I am looking to purchase:
http://www.ebay.co.uk/itm/FORD-MONDEO-TDCI-6SP-DUAL-MASS-FLYWHEEL-REPLACEMENT-FLYWHEEL-CLUTCH-CSC-BOLTS-/371122786745?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3AMondeo&hash=item5668a451b9
Are these the right bits I am looking at, anything else I should be considering? Any advice would be appreciated :)
The bits for your crankshaft damper pulley look to be correct, I'm going through the same process myself in a couple of weeks. But have you checked further to find 'sets'> They sometimes work out better.
As for the DMF issue, I am a little concerned that the list says '6 speed'. is yours a 6speed, if not check, otherwise fine.
Hopefully that helps.
