Removing Underbonnet Insulation
Hi folks.
Need to get to my screen washer heating plugs to disconnect them as I think they are causing my fuse to blow and this fuse is also for the C/control and Air/con.
Is it just a case of carefully prising out the round plastic clips or do they turn and release?
Barrie
You just prise out the round plastic clips (and just push them back in when you are finished) - careful with the insulation as its fairly easily torn
Thanks, got it off and disconnected washer heaters.
Cheers
