2001 Front Wheel Bearing
wee bit help folks. which side is the abs ring.
post-57536-0-38934300-1413635132_thumb.j
post-57536-0-25923000-1413635138_thumb.j
Nether, as it's not built into the bearing. The ABS ring should be separate.
I thought the mk3 used a bearing with the abs ring built in. That doesn't look like an abs bearing though
I normally just replace the whole hub, without the need of just replacing bearing (cost's about same for full hub for me). But as far as I'm aware, the ABS ring sits just inside hub.
