Mk1 Power Window Total Closure Mod Install
hi guys and gals, I have got one of these falcon 2 window closure interface mods to close windows when I look the car, I have sorted out the wiring from the interface to the car and I know what wires to tap into in the car (between the switch and the motor) the issue is thus, do I have to remove the door car to tap into the this (yellow wire for driver side and the yellow/velvet wire for passenger) or is there other wire with-in the car I can tap into to save removal of the door card.
Cheers
Best to remove door card. But you should be able to access it from behind the kick panel. But there are loads of wires there so keep it easy.
Cheers, ive sorted it now took the driver side panel off for the yellow wire and found the yellow/violet wire in the floor near drivers seat. Done a little testing with a multi meter and soldered into wirring and used heat shrink on all cables. Will have to do a write up thanks
