Diagnostic Software
i have an odb11 reader anyone know of any free softwear for my 2005 fusion 1.4 petrol thanks
Try forscan.
tried doesnt seem to work ,might be a bad copy anywhere i can d/load another
cheer s
  • 5 weeks later...
FORSCAN is the best but you need a modified ELM cable to get the best from it.
hi,i have ford fusion 1.4 2005 model car.. my car has the problem with the throttle body...so the garage man recommended me to replace it...
if i buy a used one or new one,do i need to reprogrammed it with my car???
many thanks
11
11
Throttle body should be a straight swap if that is the issue
Hi,thanks for your replay...if I buy a used one(I mean,from the same model) after I fix it, do I need to reprogram it on my car...one of my college says that,still I may need to reprogram it to make suitable with my car...
I don't believe so, especially if the parts numbers are the same, it's only if the parts are completely different.
  • 3 weeks later...
hi,sorry for the late reply... I used a diagnostic program myself with forscan and found a fault code... I couldn't clearly understand the error details...
it was..
===PCM DTC P2119-E0===
Code: P2119 - Electronic throttle position controller - throttle flap malfunction.
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is On for this DTC
Module: Powertrain Control Module
Diagnostic Trouble Code details
Refer to TSB number 76/2003
Throttle plate has not moved to the requested position in the required time.
Remove the duct and check for an obstruction at the throttle plate.
Check the throttle plate for evidence of mechanical damage.
Faulty ETB motor voltage
Check the ETB connector for damage.
Faulty ETB
===END PCM DTC P2119-E0===
===OBDII DTC None===
Successfull DTC reading, no error codes found
Module: On Board Diagnostic II
===END OBDII DTC None===
===IC DTC None===
Module: Instrument Cluster
===END IC DTC None===
===RCM DTC None===
Module: Restraint Control Module
===END RCM DTC None===
===GEM DTC None===
Module: Generic Electronic Module
===END GEM DTC None===
===ABS DTC B1318===
Code: B1318 - Battery voltage Low
Module: Anti-Lock Brake / Traction Control Module
Battery Voltage Low
This DTC may be caused by :
Check fuses.
Power supply to fuse
Discharged or faulty battery.
Check the condition of the battery.
Check the battery charging system.
Check the connector for damage or contamination.
Check the connectors and wiring harness for damage or contamination.
Check the wiring and the appropriate fuse.
High resistance in wiring
Additional Information
The ABS lamp should be illuminated.
The ESP lamp should be illuminated.
There will be an ESP malfunction warning displayed on the driver information text panel.
===END ABS DTC B1318===
so does the error details mean,do i need to replace the throttle body or....????
Elm-FFN
Probably means you need to clean it and the connectors rather than replace straight up.
