Tailgate Badge
Advice on best way to remove Ford tailgate badge on Mondeo?
Why do you want to remove it?. if its peeling then ford dealers will change it for free, I think its available till December, If you must remove it then put masking tape on body across end and use thin screwdriver or knife to gently lever off they are only stuck on.
Heating the badge up with a hair drier or similar will help the adhesive loosen off a lot easier. You should then be able to gently prise it away from the tailgate.
Same often works for helping new badges to stick on as well!
I can confirm they change them for free - just had mine done today :)
