Mondeo Injectors Problem
HI, My mondeo needed 3 new injectors as they were in a bad condition and most diesel went out through the leak of pipes, i bought a set of 3 second hand ones and had the bad ones replaced, after being fitted and coded the injectors wont inject fuel, they have fuel going to them but not into the barrel. Car shows no error codes or anything. I have also checked fuses and they all seem to be fine.
Does anyone have a idea of whats wrong with the car?
Car has done 160K miles
You have replaced the injectors with used parts, the fuel gets into the fuel line but not the Injector? Is that on all 3 as if it was I would say (presuming you have coded then properly ) you have 3 bad injectors
Its on all 4, including the one the worked before for sure, i had them coded and replaced by a mechanic who has run out of idea for what can be causing this problem.
I might call in a diesel mechanic this week so he can check it
i have read on a different forum that by towing the car for 2 miles and with use of easy start someone managed to get theirs with the same symptoms started, would that help ? Im worried about doing it as i have no idea if the car had the timing chain replaced and im worried it will jump.
If fuel isn't getting into the injectors then the issue is more likely related to either the fuel rail or filter. It's perhaps now got an air lock in the system meaning you should probably prime it by hand. I would suggest replacing the fuel filter ad a matter of course
I had the filter replaced about 100miles ago but ill for sure try and prime it as soon as im able to and if that works ill buy a new filter.
