05 Mondeo Charge Light
I have recently purchased a 05 Mondeo 2lt tdci....apart from a new DMF clutch crank pulley belt tensuoner etc I have a annoying intermittant problem with the battery light intermitantly coming on ...If i switch of the engine and restart it goes out and stays off ..the car has a new looking alternator starts first time with no sign of excessive battery drain ..anyone have any ideas , there does not seem to be any physical symptoms , just a annoyance
Steve
Please tell me it's not an RTX alternator
Pass ......could you please explain..I have been told it is fairly new it looks clean ....and the battery is suppossibly OK.... But that is what the dealer has said
check the 3 pin connector for corroded pins, and security of fit on to alternator.
OK thanks will check it out could that explain the intermittent nature...and why it goes out when I restart the car ???
