Blue Tooth
Hi all just joined on here so just a quick question I have bought a 08 Mondeo 2l tdci Giha and I have tried to link my phone to the stereo and it just mutes it all? Any help would be helpful thanks
Which stereo do you have ?
Sony 6 disc multi changer it has the buttons for the phone on it
It hasn't got Bluetooth built in I'm sorry to say.
Oh ok then can I buy something to make it Bluetooth enabled
The radios do not have built in Bluetooth, the Bluetooth module sits above the glovebox,, so you will have to remove the glovebox, and get on your back thru the passenger door to peer under the the dash to see if or what module is fitted, a torch or light will help. post details for more help.
Edit: also enter your reg on etis and it will give your build spec and say whether you had Bluetooth at build.
  • 3 weeks later...
Hello I have same problem and on the site which you said about said
BT/VC Phone Interface Only
What do I need to do.?
I have the same Sony 6 CD player. I have mk3 ford mondeo ghia x.
Chris
as above and give module number, then somebody may be able to give more positive help, perhaps your module may been removed, faulty or loose connection,
Thank you will post when I have check
Sorry but above applies to mk4 not sure where module is on mk3
Thank you any way, I think I found another topic on here which says where it located. I will see what the out come is and keep this updated
