95 fiesta
while driving i come to a stop and the engine dies can anyone help???
you should try posting under the fiesta section it may get you noticed more by others.
it sounds to me like you have a problem with the 'idle speed control actuator' or a vacuum leak somewhere but im not familiar with the older fiesta's
Could be a split pipe or the idle control valve needing cleaned.
Check the rubber pipes that are attached to the oil filler cap and trace them back there's a T-piece that usually causes problems. If one of the pipes are split you should hear a hissing sound
If not then clean out the idle control valve. There's guides on the Internet if you do a google search
thank you .
