MK7 3 Door Rear Seat Noise
I have had my car for just over a month now and it has got a really annoying creaking noise coming from the back seat at random times is this a common fault? and is it worth taking it to the dealership or just wd40 it?
I collapsed the seat and then slammed it back which fixed it 4 a while but now its back again but its seems a bit of a waste taking it back just 4 that
I'd take it back and then take someone out to let them hear it - you never know it might be something very simple like a missing rubber pad
Hi,mine did it from day 1.I ended up just spraying hinges with wd 40, it solved it on mine. :lol:
Had the same pulled the back of the seats down and put a small amount of vaseline on the pins and catches on the back rests, cured not come back..
might giv it a go with the wd40 1st see if that solves it my ford dealership will probably want to keep it in overnight 4 them 2 fix it
thanks il try both then i cant go wrong :)
The mk6 was well known for this problem. A bit of white grease on the catches sorted it, wd40 would sort it but would just attract dust and dirt over time.
So will grease :rolleyes:
Sorry ment to say white grease or service grease. It's what the dealers use to spray on your door locks and hinges.
Sorry ment to say white grease or service grease. It's what the dealers use to spray on your door locks and hinges when you put your car in for a service.
got this problem as well , its like a creaking buzz sound ?
Sorry about the double post above
It's usually a sort of squeaky or clicking sort of sound. On the mk6 that is. I'm assuming it's the same problem the mk7s are having
