Help
Should this seem like it's blocked ?
Is that a fuel pressure regulator? Which end are you blowing into? Did you put a vacuum on it, this opens the valve.
Not sure how to test it I just did the standard blow into it on both ends and sucked nothing happens
You blow into the big pipe and apply a vacuum to the small pipe, that opens the valve.
