Fan And Cigarette Lighter Not Working, And Fuse Confusion!
I would say the little expense of parts for both would be a worthwhile investment personally. I suppose the labour costs would be the deciding factor.
Sent from my GT-I9195 using Tapatalk
Thanks James.
I can replace both of the parts myself as they're just done by removing the radio, screws and unplugging the old ones etc.
I think I will give it a whirl. Thanks again for your support.
Good luck, hopefully a cheap and cheerful fix.
OK, don't laugh, but one of the removal keys has snapped in the radio :o(
See the attached image for what I mean. Do you have any ideas on how I can get the key out, or remove the radio another way?
I need to get the radio out to remove the piece of dashboard, so I can replace the heater control.
post-67458-0-17099500-1440870012_thumb.j
Hmm that's a bad one. You can try getting a magnet and enticing it out and you may also need a tweezer to pull it out...
You could try this
https://www.google.co.uk/url?sa=t&source=web&rct=j&url=http://m.youtube.com/watch%3Fv%3DSvHUJx5kygo&ved=0CCwQtwIwBGoVChMIqNS38vPOxwIVzwjbCh0UzgBM&usg=AFQjCNGjPnA1AeAoSOXDHGVEhEJXq-yHww&sig2=yb4hPl-ITm_B9oa8eSPI9Q
Thanks James.
I've felt around the back of the stereo, and there is a clip or screw at the same point as the pin which is jammed.
Would it be worth bending/snapping that one pin off so I can get the radio out and replace the fan switches?
Without getting the radio out, I am unable to swap out the part and see what the issue is.
You could probably try but how much of a grip it holds is anyone's guess.
Hello I am a new, if old member, not very computer savvy, however I have a problem with my 2011 ford fiesta, cigar lighter suddenly packed up so no sat nav, RAC checked all fuses and have told me to contact main dealer and mention B10 U 3000 control module B10EA and U0193 no communication, help anyone please !!!
Hi Brian, I am not a mechanic y any means, but could it be that the cigarette lighter has broken in some way, and you have to replace the component? Do you have a second cigarette lighter point in the car?
