An 06 Focus 1.6tdci Has A Dpf Doesn't It
The 110hp model...if so I'll leave it
  • Replies 111
  • Views 9k
  • What's wrong with Ecuadors current maps?
  • 😠predictive text
  • Do you know you lot have a horrible hatred of the 1.6 engine and put people off buying it all the time, it is most likely no less reliable than either the 1.8 or 2.0 diesels in the grand scheme of thi
it's a Citröen/Peugeot engine and most likely has the eloys fluid type dpf.
other common problem is leaking fuel injectors and text book turbo failure at around 120k if dpf isn't gutted and egr blanked to prevent oil from being contaminated with carbon deposits and dpf clogging causing cavitation in the turbo.
if buying your much better off purchasing a 1.8TDCi
no dpf and it's a Ford engine.
I have a 1.6TDCi bought unaware of the common problems,
Spent 1200 in preventative maintenance at 20,000 miles on clock and it's now got 180,000 on clock with no failures
still cheaper in the long run to purchase a 1.8TDCi
My advice would be to run away as fast as you can if it's the dreaded DV6 with all the issues :)
Edited by MONDEO TXS 2.2
Thanks, I thought so....what's dv6
I still want an estate though as the hatch isn't enough in the back
Very tempted with an old 01 Octavia 1.9 estate, it's someone the mechanic I use knows
Very tempted with an old 01 Octavia 1.9, it's someone the mechanic I use knows
DV6 is the model of engine that is the 1.6 diesel
full name 1.6TDCi DV6 engine
it's emissions based has dpf and egr
see discussion regarding egr valve here:
http://www.fordownersclub.com/forums/topic/42915-guide-fitting-egr-blanking-plate-16tdci-engine/
Blank the egr valve,
Flush out carbon from engine oil
Have the dog internally removed
ECU remapped
oil breather catch tank
then only problem you have to watch out for is; leaking injectors
DV6 ( TED4 ) is the dodgy engine model
Ecuador remapped
Remapping Ecuador could be expensive :)
But much cheaper than rectifying a DV6 TED4 engine ! :)
😠predictive text
I think it's probably best left....nice car but only an lx model too
no aircon or alloys 😕
did you win it in a Raffle and are now wondering "should I go collect it"
see discussion regarding egr valve here:http://www.fordownersclub.com/forums/topic/42915-guide-fitting-egr-blanking-plate-16tdci-engine/
ECU remapped
Thanks for the link but it's for the egr, it's the dpf that's the problem or will be in future if I got it
It's a good car - crippled by a duff engine
no aircon or alloys
Yes has both
Yes, just to complicate matters I believe it has a dpf too
Yep...bollox
both are equally a big problem mate,
Dpf collects it
and
the egr puts it back in to the engine induction
Egr is like the hand that scoops up the poo and puts it in the mouth of the individual whom discharged it just like Gorillas in winter eat there own poo to keep warm 😉
all modern diesels have egr valves
blanking it is very much advised stops exhaust gas recirculation
I know, I've blanked mine, it's the first thing I did, I can live with that but the dpf is different and a right pita
!Removed! shame as I really like the car and a lot of history ect with it......still needs a few wear/tear things done but a dpf is a no no
I've had my dpf cut open on factory weld,
Internal gutted and weld back up on factory joint
Refitted and remapped has no smoke and lower emissions than factory spec plus it appears to be completely factory as the dpf chamber is as it should be 👨
Ok...I'm tempted but it's more money, plus the mot place I use the guy's really on the ball, he's good but hard/fair....I'll think about it but I'd be a few hundred to get it all done as a map's 3-400 alone
I agree mate,
I say to people; if you find yourself stuck with a 1.6TDCi, it's worth spending up to 1500 on preventive maintenance
However
if buying a 1.6TDCi save an extra 1500 and get a 1.8TDCi if possible as it's a much better engine, still has egr but no dpf and no worry
It's a 1.8 I've got but want more space in the back hence an estate
My 1.6tdci doesn't have a dpf...
