Ngk Spark Plug Issue ?
I have a misfire problem only on start ,runs fine after 3 secs ,could this be same problem ,its on a fiesta 1,25 11 plate ,please help ,thanks
  • 1 month later...
NGK plugs work perfectly in this engine.
However, NGK & Bosch (the FoMoCo plug) are standard plugs.
Personally I'd use Denso Nickel TwinTip - TV16TT
Ford OE Number: 1787829
Bosch: 0 242 236 633 (HR7 MEV)
NGK: 4559 (TR5B-13)
Denso: T16VR-U10
Above are all STANDARD plugs. Below are uprated plugs:
Denso: TV16TT -Nickel TwinTip
Denso: ITV16TT - Iridium TwinTip
The Ford service interval of 37,500miles/3yrs is daft for standard plugs. If using standard then renew every 20,000miles at least. Iridium is fine for 30,000miles
A final thing.
The reason NGK may cause issues is that they have a 1.3mm gap - if the engine/ignition system is not running 100% you may have slight misfires. But, if not, the engine will be slightly more economical (teeny tiny amount)
OE Ford/Bosch have 1.2mm gap
Denso run 1.0mm gap and will last longer and be more reliable.
