Lighting Problem
And if no power there, then you have internal failure of the fusebox
  • Replies 52
  • Views 6.5k
Aka, have fun & good luck ;)
Sent from my HTC One_M8 using Tapatalk
Fuse 103 you need to check
Brilliant Ian BIG THANK YOU. Just popped out to sort it all's fine now. I dont know how I missed that one fuse. cheers Ian
I was going to get a second hand fuse board in the morning to try to rectify the problem. So you saved me a few bucks Thanks again Ian
Moving post to correct section*
Sorry for any hassle.
no problem , here to help, next thing is why did it blow, check all lights work, probably high resistance in one of the lighting circuits or a dodgey bulb
we got there in the end.lol
As a new member you should read any "stickies". That way you won't make mistakes :)
Don't worry about it, just go back and give all the stickies a read and all is good.
Had to change a headlight bulb maybe that was the culprit.
Quite likely
nope
ha ha
nope
ha ha
Surely the bulb blowing could have caused it?
I've had filament bulbs at work trip dimmer cards when they blow..
Although they're 750w+ not 30~ ;)
ive never read any stickies , what are they? :)
Shh, neither have I ;)
I learnt by making mistakes haha
not a headlight bulb, on a different fused circuit,
I didn't read which fuse had blown ;)
The headlights are on separate circuits aren't they! My mistake
thats what your on here for anyway, move posts about and lock others. ha ha
And to keep you all under control & behaving! Haha
in your dreams !!
in your dreams !!
I have to admit.. the number of bans ha dropped considerably recently! Must be the festive magic :)
thats because im on here keeping eveyone happy. :) :) :) :) :)
Could well be!
My car's sure happier thanks to you
I found a damaged parking light wire behind the headlight where I had tapped into ages ago for some led strips. I used a scotch connector I guess they are not the best just the easiest.Would this be the cause? I have done a temp repair till the rain stops.
yep , that could be it,
If you wouldn't mind Ian. as my wife also drives the car and the reverse light is so bad, I fitted reverse sensors a few months ago. I fitted a reverse camera a month ago and the sensors stopped working days later. Do you think its too much of a draw. they are both wired to reverse light wiring.
so the sensors stopped working but the camera still works? if thats the case then sounds like poor connection for sensor power or earth, if theres to much draw then reverse fuse will blow, or even the sensors/module is faulty and a coincidence.
