Interior Bulb Fiesta Mk6
Hi
Mwhat bulb do I need for interior in my fiesta 1.6 tdci s 57 plate
If I remember correctly I had a 42mm festoon bulb although mine was a pre-facelight without the mapping lights so may be different.
No its not the same as number plate I have different one
Does it look like the picture below. If so its a 501 / w5w
post-58329-0-39138300-1452096441_thumb.j
Yes exactly this ine
And what kind of bulb goes to boot? Same as interior ?
Yeah, same with the sidelights
I'd recommend buying an LED 501 for the boot light or installing multiple as i have in my build log. the one factory boot light is appalling
My fiesta has
38mm reg light bulbs
42mm festoon bulb
small bayonet things for Maplights, although ive replaced these with small curled up LED strips
That is exactly what I ordered http://www.ebay.co.uk/ulk/itm/120695320468
So I can use one for interior one for boot :)
What sort of bulbs and how to fit under steering wheel I saw people have ite
Do you have the bulb holders in place? If not, run a feed from the interior light bulb holder & install LED strips of your choice :)
www.yorkshiredetailing.co.uk - approved resellers of the Highest quality Detailing & Valeting supplies
How will it work ? When I open doors only ? Or how will it work ?
That depends how you wire it.
If you wire it to the switched earth (door open) and the +12 then they'll only come on when you open the door
If you wire them to the Constant earth & 12v+ then they'll be on all the time until the battery saver relay kicks in after 20 minutes of the car being locked. I've wired my self dimming mirror to this feed.
If you wire it to the bulbholder, they will come on anytime your interior light is on, regardless of whether you switch it on or open the doors :)
Oh yes that sound nice but where I feed the wire from ? From the interior and then from
To sides to bottom yes
http://www.ebay.co.uk/ulk/itm/291306316790 Are these good ? But only 30 cm length of cable
Feed the wire from the bulb holder, through the headlining, down the pillar, behind the door seal & then you're there
Get some DRLs. The solid rectangular self adhesive COB SMD ones. Much wider light pattern & they're brighter if you want to add colour then order some Lee filters gel. I can advise you on numbers
Send me link please I will buy it
Now
Did you want to add a colour?
These ones are UK EBay 201359323472
These are the ones I ordered from China & work perfectly. same thing.
EBay 351500071807
It may seem like a faff, but I've tried strips in the car before and they were horrendous. bad light output & unreliable. So I use DRLs in the front & solid aluminium mounted strips under the seats for the rear
All i need is these is there enough of cable I will get these from uk not much more expensive than the ones from china it takes long for items to arrive from china
Off topic
Bought yestrday new tyre front left do I need to buy the right one is well it is still ok my friend told me it can damage thinks like bearing etc if you have one new one part worn
You'll need about 3 metres a side ideally so you've slack.
Mixing tyres won't do any damage as long as they're the same size. Ideally you shouldn't mix tyres on the same axle as their tread pattern may be different resulting in grip issues. I believe mixing tyre makes/models is an MOT failure? Or an advisory atleast. Your insurance may well use it as an excuse not to pay out too
Will get the other one today, as for the cable I need to buy it seperate or it comes with the lights ? Please send me link for cable if needed to buy seperate
You can just use cheap (not too cheap) Speaker cable as the LEDs draw minimul current :)
EBay 331224888727
I have ordered the lights for 3.59 is it enogh 2 ? Are they strong ? i will try find some cable home I must have some if not I buy the one on ebay
