Interior Bulb Fiesta Mk6
Trust me, 1 a side is more than enough!
www.yorkshiredetailing.co.uk - approved resellers of the Highest quality Detailing & Valeting supplies
Oh and yes how will i connect it to interior just simple anywhere ??
Stick one to the underside of the fuse box & stick one to a piece of plastic in the driver footwell. It's obvious when you look. The adhesive should work perfectly on its own permanently if you clean the surface first
Does it matter what colour goeswhere sobassically only one of the two wireswill be connected to bulb ans other anywhere on plastic?
On the DRL there's a + & - wire. they'll either be black wires that are labelled, or red and black.
Red = +
Black = -
Connect the speaker wire + to DRL +
Connect the speaker wire - to DRL -
Now that's wired, remove the interior light cover but leave it plugged in & in place for now.
Either use a multimeter, or put one end of the speaker wire to one end of the bulb holder. Switch on the interior light. If the LEDs work, you've found the correct polarity. If they don't, then remove the speaker cable and insert them at the opposite way. Take notice of what colour went where. Remove the interior light and solder the wires on. Alternatively, wrapp them round the track on the rear and insulate with tape
What is drl ?? Need to explain bit more in detail lol
Daytime running light. It's what you'll be using as a footwell light. Its what I use as footwell lights
When i get the lights will try if I do no what I will ask you thank you i cannot wait it must be very nice
If you struggle then ill send you my number or something and I'll talk you through it step by step
Great thanks mate appreciate it will do I i have difficulties
Btw I just fitted the k&n air filter it sounds better now kind of whistles I had service in ford they did not change air filter it was so dirty
We're they supposed to change their air filter? What else were they supposed to change? I'd check they've done the other jobs they're claiming do have..
I am not sure I had oil changed oil
Filter and brakes checked etc not sure if they should change air filter I will go
Tomorrow double check and take the old air filter and show them
I'd dip the oil and see what colour it is
I'd also check if they've changed the plugs by removing and checking for signs of rust or anything
Yes the oil is nice and clean i checked that next day and checked now its still nice and clean what kind of plugs ???
