Alloy wheel nuts
I've just got some guenuine ford alloy wheels to replace the steel ones on my focus which are the same size but not sure if I need to change the nuts for alloy ones ?
Yes.
If you don't then you may get galvanic corrosion and the shape of the contact collar on the bolt may be wrong.
You need to check whether the rims need tapered or flat collars.
