Headlight Brows
Hi all.
Have seen a few cars with brows on the headlights, was wondering where i would get them and how easy they are to install.
Cheers
Fiesta Zetec S Red Edition
Triple R Composites. They take about 2 weeks to be delivered and they only come in black.
Cheers mate, black is perfect for me. Any idea what they are like to fit?
No probs. I received mine the other day but haven't put them on yet. There is a thin strip of 3M tape to stick down onto the top of the headlight housing. Will try and get a picture in my lunch hour :smile:
I read one of their fitting guides and it was talking about removing the grill etc? If you can get some pics I'd appreciate it.
Also maybe a really daft question but is my red edition mk7 or 7.5...?
Oh right, fancy linking me to that pal? Yea sure, will get some when I fit them too!
Yours in the mk7.5. They never made red Editions on the mk7's.
This is a mk7 (pre-facelift)
And this is a mk7.5 (facelift)
@Tom-B64  Although they do say they used MK7, Maybe its different for MK7.5. Might want to give them a call,
LIGHT BROWS.
We have used the Ford Fiesta Mk7 brows as an example here.
As with the bonnet lips these are also pre-fitted with super strong 3M double sided tape.
Our light brows can easily be fitted within a couple of minutes.
Step 1. Preparing the headlights.
First off you will need to prepare your headlights. To do this you will need to remove any wax and debris that will have built up over time.
We use a Meguires high cut polish to do this, any high cut polish will do.
Use a bit of elbow grease to make sure you get through all the dirt.
Step 2. Gaining access.
On the Mk7 Fiesta you will need to remove the 4 black plastic push clips that hold the grill section of the bumper in place.
This is easily done using a paint scraper, remove the central piece of each clip first then the main part.
Step 3. Fitting the lightbrows.
Remove the backing off the 3M double sided tape, slip the front section of the lightbrow down between the grill and the headlight and stick the back part down to the headlight. Ensure it is stuck properly by apply a good amount of pressure.
Step 4. Finishing the job.
Once you have both the light brows in place refit the clips along the top of your grill in reverse of Step 2 and the jobs done.
If you have any problems at all please don’t hesitate to contact us for help.
