Ford Focus won't crank
Hi my Ford Focus won't crank. I turn the key and lights come on but nothing. It will bump start and will start if I put screw driver across the starter motor. Help please
What do you mean across the starter?
Ignition barrel fault? Relay?
Hi I took the ignition switch off to try start it with screwdriver and it still did the same so didn't use the barrel
I put a screw driver across the 2 terminals and it cranked over and started
you will need to check relay k22 in the fusebox behind glovebox , top left relay from what i can remember.
