Antom
Hi everybody new to this taught is try ask for advice about something and where better to try I've bought a 05 Ford Focus mk2 I've changed the radio to the mk2.5 to try get phone working trough it woundering if anybody any info on it think I have to install a Bluetooth module but is this possible easy or even worth the money or best off trying a parrot type device thanks for any info
An oem bluetooth system is expensive and fiddly to fit.
You'd need a compatible module, loom and microphone.
A Parrot system is easier and cheaper to source plus is far better for functionality.
The mki9100 system has aux and usb input for music and would tick a lot of boxes as it can stream music via a2dp.
The microphone is designed to stick wherever you want so will reduce the amount of wires you'll need to run.
Sent from my SM-G930F
