Bluetooth stopped working
So i normally always use bluetooth in my car, but randomly is has stopped working, it just says error connecting?
Only thing I can think of is that I havent updated my phone to the most recent iphone patch? Im only 1 patch behind? Any ideas? Its seriously bugging me
I've found that if you turn off your ignition. Unplug the sync fuse (refer to manual) wait 30 seconds, turn the engine on, wait 30 seconds, turn back off, plug fuse back into correct fuse slot, turn engine back on. It should work?
This is up to you if you do this. (I can't remember if I did this part or not) Clear your BT DEVICES in your fiesta menu prior to  removing the sync fuse and set them to be forgotten from your phone too. Then re-pair them back up once the aforementioned steps are complete.
Hope this helps.
You might find your sync playing up once every 3month or so...
Mine does. And many others do... But it won't become a pest...
Cookey.
Hope this helps.
Cookey.
Cheers mate, Im going to update my phone, see if that changes anything, if not I'll try this. Pain in the ar$e!
