How To Top Up Steering Fluid?
When car is stationary I hear a drone when turning the steering wheel. Had a look at what I'm guessing is the power steering bottle and couldn't see any fluid moving around.
But what a crazy location!...how do you access it to top it up?
Ah forget that, that pic is of the Brake/clutch fluid reservoir.
So where can you monitor the level on a 55 plate Focus?....the handbook says "no fluid level checks necessary" for 1.8/2.0 l Duratec-HE, 2.5 l Duratec-ST and Turbo diesel engines"
How does that work?
its hydroelectric pump, there is a bottle attached to the electric pump, remove the o/s headlamp and you will see it, if the fluid is low then the leak needs finding.
The picture you have posted is your brake/clutch fluid reservoir. The power steering pump reservoir is under the driver's side headlight. Remove the headlight and you will see it.
Not relevant to the PAS fluid I know but is that actually how your brake fluid reservoir is?  Mine has another little reservoir that bolts to those 2 holes on the plastic scuttle in front which are in your picture.  You'd need to the scuttle panels to top up the brake fluid which seems odd!
Nearly as odd as having to remove a headlight to top up PAS fluid I suppose.  Won't be long until you need to remove a wing to top up screenwash at this rate... :tongue:
Designed by some who rides a pushiron and does not drive. No idea we have to access these things from time to time
had to remove wings on citroen 2cv to change spark plugs
41 minutes ago, iantt said:
2CV..........spark  plugs
it had more than 1 ?
:biggrin:
yes 2!! and 29hp. lol
Because you don't need to top up your brake fluid. If you do there's a leak somewhere and that's the least of your problem.
Or remove the wheel and wing liner to change the headlamp bulb on a Renault Megane!
  • 5 years later...
I have a 13 plate ford focus and I have a sqweeking steering wheel like a rubber sqweek could this be the fluid but apparently there is no fluid for this one
Correct, no fluid on the Mk3, it's a full electric motor on the steering rack.  If the squeak is coming from the steering wheel area, it's not actually a fault but is very annoying, mine used to do it a lot and my Golf does it in the cold.  Not really anything you can do about it.
