Mk3 EGR valve Stuck?
With a flashing glow plug light and loss of power, I removed the EGR valve to find it badly gunked up. I've cleaned it using carb cleaner, reassembled and found no difference. I have it off again and have found that the valve seems to be solid. So my question is, should I be able to move the valve at all?  Seems to be in the closed position but thought I'd be able to open it against a spring with my finger. Is it a case of needing more cleaner left to soak around the valve stem? Any help would be appreciated!
Try to drive with the EGR disconnected ( disconnecting vacuum hose ), making sure that the valve is in closed position.
If the result stays the same, I would examine the hose from EGR to IC, that  might be torn
Do you have black smoke, Soot ..on limp mode?
