Low idealing and Shakey
Hi all
Purchased a mondeo 2.0l petrol 58 plate a few months ago and have now started have a few problems seems a bit dodgy on starting and it low ideals at around 500-700 rpm and wont sit at about 1100 unless you rev it up first and then its fine? also it just turned its self off the other day when partner was driving it.
Worth calling the garage I got it from has a few days of engine and gearbox warrenty left?
Hi There
Yes if there is still warranty left on it get it back asap - Sounds like it could be the idle air control valve sticking - Get it looked at / cleaned out and run a diagnostics check on it - Worth while checking the air filter and surrounding pipe work for split vacuum pipes or pipes that have came off there location
23 hours ago, Jensen said:
Hi There
Thanks its going back today to have a look but I bet they don't find anything or wont do the problem when im there
