Looking for a reversing camera adaptor
On 3/21/2021 at 4:37 AM, JW1982 said:
Blue = GPS.
Black = FM antenna (required for TMC reception).
Pink = FM antenna (pass through from FCDIM to ACM).
These are regular 2-pole Fakra connectors.
Can anyone tell me where to find the Green Reverse camera female connector? Is it this one? https://www.co-star.co.uk/4854/hsd-code-z-water-blue-female-crimp-hsd-01da535zpgn/
  • 1 year later...
  • Replies 51
  • Views 39.1k
  • In that case I would just find a rosenberger HSD connector from a electronic component supplier and make the adapter cable myself.
  • Pin 1 and Pin 2 of the Rosenberger HSD connector are used for the video signal from the rear view camera. Pin 3 and Pin 4 are not used. The type of connector you need is a Rosenberger HSD type E
  • I bought a gps antenna from Amazon and the farak patch lead from their too so the black dab lead (from the car) goes into the back of the display ( was in the back of the head unit) then the
Hello,
hello,
i have (secondhand) stline 20018 with Sync 3 and does not have standard reverse camera. I have on my hand the factory camera and i would like to mounting. Can any one to give me a guide what exacly  wiriring  i will need for ? Some dealers here in Greece they told me that i need 1 or 2 wiring as the attachment pic, but i dont took clear answer.
I am sure that red wiring is missing and before to buy (about 100€) want to be sure for that.
Does any one have experience with mk8  to give a retrofit guide ??
