USB query
Hello,I have just removed the glovebox out of my Mondeo titanium x to see if I could put a USB port in to allow music streaming.i have pulled the cable down and I'm not quite sure what to do next?have I got to upgrade the Bluetooth unit or can I get a lead that plugs into this and then into the USB port I've got?
I'm don't think you can just plug a usb lead into it.
I have the same unit in my car, I also believe that the newer modules that allow usb and streaming are not compatible with our setup.
Hopefully I'm wrong.
The label will say with USB if it has it, although the older modules have a USB port it is a service port only.
so if it doesn't say USB on the label, then it doesn't have it.
Cannot read the module number on your photos but the old module wthout usb is 8M5T-19G488-AX and the newer module with USB is8M5T-19C112-AX The last number X being the issue , if you want streaming from phone then it needs to be issue N or later.
