St150 gearbox blown/clutch?
This morning on way to work I think my slave cylinder is gonne same as clutch not sure if it is gearbox as well oil came out and the clutch pedal is loose dead what I include pictures how muchI am looking at for fix ? Car is on 76k
Concentric slave cylinder? Seems likely, but no way of knowing without dropping the box.
Yeah hopefully its clutch ! Im not sure its gearbox oil that came out or brake fluid my brake fluid reservoir is half of it
Aye, the reservoir is divided in such a way that a clutch leak won't cause a brake failure.
Ahhh so its all good then I am getting towed to garage today so brakes will work that is good I was worried
Car is in garage got towed and on dashboard popped msg saying low brake fluid level check owners guide so I guess it was brake fluid That leaked I ordered new clutch from euro car parts £250 LUK brand
Its gearbox as well it has hole inside !!!
Holy Corbyn! What's happened to it?
You been racing around, Patrico777?
There is hole in box its self from bottom not sure what happend
No driving normally not saying like granny did push it a bit but that what is made for the car
I feel your pain Bro.  New box?
Looking at the pics there is no way that is brake fluid, far too much of it and also wrong colour.
an expensive day out for you.
Oh yeah it cost me £700 in total box new clutch labour
Just this here wheb twisted is bit noisy seller said will be fine once installed on car
the input shaft is twisted? no danger would i even attempt to fit that.
No when mechanic have twisted this highlighted there on pic it made little noise seller said once fitted wil be fine
ah you mean when rotated? it is a little noisy. Sorry it read to me that the input shaft was twisted lol
Yeah when rotated sorry I am so fed up that I dont even no what I am saying hahaha makes little noise when rotated
It'll make a little, particularly if the box has been dry for a while, but if the shaft rotates smoothly and feels smooth you should hopefully be fine.
Yeah turns nice and smoothly no problem at all getting it fitted latest on Sunday
Just got the job done the gear knob feels so stiff, clutch is nice and smooth what could be the problem?
there is picture of old gearbox broken and also new one installed
Clutch bled out properly?  Clutch properly aligned on the flywheel?  None of the gear cables snagged or trapped?
I hope so I will call that guy ask him as it just does not seem right
We can check that but all I've done is remove and refit
he said
